Pros and Cons of Aluminum French Doors
Lead Image for Pros and Cons of Aluminum French Doors
When it comes to installing aluminum french doors, you will want to make sure that you explore all of the pros and cons. Here is a little information that can help you with the decision.
Aluminum Is Stable
Aluminum doors provide a lot more stability than both vinyl and wood doors. Depending on the weather, wood can swell or shrink and vinyl material is not as sturdy as aluminum.
Readily Available
You can find aluminum doors at almost every household and hardware store as well as online.
Easy Maintenance
Aluminum is easy to clean and maintain. You can wipe it down with a wide variety of cleaners. This is opposed to wood, which needs special treatment. Also, aluminum does not rust so you won't have to worry about replacing the door as quickly or maintaining that aspect of it.
Modern Design
Aluminum is a great way to compliment any modern design in your home. It provides stability, but it also matches great and ties in with the style and design look that you are trying to achieve.
Aluminum Oxidates
Because this type of door is made out of aluminum oxidates, it tends to result in a white residue on the surface. After a long period of time, the white residue turns into pitting on the door. If you maintain this consistently, you can prolong the life of the door. You do have to be sure that you are diligent about cleaning. Also, although this material is easy to clean and maintain, it does tend to dull quickly so your cleaning sessions will have to be close together.
Water Stains
Water stains tend to be one of the bigger problems when it comes to aluminum doors in general. The problem is that this material can stain easily when it comes in contact with water. You can clean it off easily however if you wait too long in between cleanings, aluminum can corrode quickly. This problem can be solved with regular maintenance but, if this does not fit your schedule, aluminum doors may not be the right material for you.
Welding Fixes
If you come to a point when your aluminum french doors need to be welded, you may run into problems. While you can typically take your doors somewhere to be welded, you cannot do it yourself. Aluminum doors can end up being an expensive thing to fix, causing you to either have to shell out all of that money for welding equipment or for a new door. Keep these costs in mind when buying the door, to begin with, so you do not get ambushed.
The bottom line is that aluminum french doors have both pros and cons. Keeping your life and design style in mind, these facts should help to guide you in deciding whether or not this type of door is best for you.
