Pros and Cons of Basement Floor Insulation
Homeowners often insulate every floor, wall, and ceiling in their homes, but frequently ignore basement floor insulation. Few contractors insulate basement floors during construction unless specifically asked to do so.
In many cases it is up to the homeowner to finish the basement on their own because the basement tends to be a mild afterthought. They are typically used for storage; only a fraction of people have taken the time to renovate and finish basements.
Before you spend the time and money placing basement floor insulation, you should know the pros and the cons of doing so. The information contained in this article will explain some of those pros and cons for basement floor insulation.
Added Livable Space
Since a basement is generally only thought of as ancillary, it is rarely used for anything other than storage. Some handy homeowners will use it for storage as well as a work room. Even if you convert the basement into a rumpus room, game room, or office, you are left with the same problems unless you have basement floor insulation.
Since a basement is several feet underground and made out of concrete,moisture will accumulate. Basement walls could crack and water could enter. Combat the moisture by adding not only basement floor insulation, but also wall and ceiling insulation. Doing so will make using a dehumidifier obsolete and allow the basement to be finished into an extra livable space.
Better Fire Safety
Basement floor insulation gives an added protection to the home as a whole against fires starting or spreading. Fire needs oxygen. If there is no oxygen to feed the flames, then the fire has no food and will die quickly if it starts at all. Concrete can withstand high temperatures, and the cool air makes a basement a tinder box for fire. Basement floor insulation keep the flow of air in check as well as level out the cool and damp areas.
Water Pipe Protection
One prime fear that a homeowner has is the fear of pipes bursting during the colder months. Water pipes run throughout the home. If these pipes freeze and burst you, are looking at thousands of dollars in repairs. Basement floor insulation can help level out the temperatures, trap heat, and prevent water from freezing inside the pipes.
Very Costly
The material used for basement floor insulation is very expensive, as is the labor. On top of that, many contractors are not familiar with the product or methods. If the soil around the home has radon gas trapped within it, you will require a mitigation system.
Insect Infestation
Many of the products used for basement floor insulation are also food for insects. They inhabit the insulation and borough through it, rendering it useless.
