Pros and Cons of Porcelain Tile Flooring
Porcelain tile flooring is a durable and easy floor covering option for many homeowners. They are easy to install and require little effort to keep them looking brand new. There are several advantages and disadvantages to porcelain tile that you should consider before you decide on the best flooring option for your situation.
Advantages
Porcelain tiles are dense and durable. This material is manufactured with refined clay. The clay is made at high temperatures which makes the tile stronger than many other ceramic options. This flooring option can last a lifetime if it is installed and maintained properly. The surface of the porcelain tile is moisture and stain-resistant. The potential for mildew growth or cracking are greatly reduced with this type of product. Porcelain is also non-porous which aids in the prevention of bacterial growth. All of these characteristics of porcelain tile make it a good option for both indoor and outdoor installations.
Disadvantages
The nature of porcelain which makes it durable also makes it difficult to cut. Typical tile snapping tools are not strong enough for this material. Diamond blade wet saws and diamond-tipped drills are required to cut or drill porcelain tiles. These tiles can also be difficult to lay onto mortar because they require extra pressure to force them into place.
