Pros and Cons of Wooden Venetian Blinds
Wooden venetian blinds are among the most common type of wooden blinds available on the market today. These blinds are generally more expensive than curtains, drapes and plastic blinds and yet, they have a lot of advantages to them such as durability, low maintenance and better control over light.
Blocking Out Light
Wooden venetian blinds are made from wooden slats that stack together when the blind is raised and they generally are attached to a string that allows adjustment of light entering your room even when the blinds are fully lowered. This is done by adjusting the angle of the slats: when the slats are angled down they block out sunlight but if they are horizontally facing each other more light is allowed to enter.
Therefore Venetian blinds tend to have better control over the light levels that enter your room because most other blinds need to be raised in order to get light, thus losing the privacy element combined to them. Hence, one of their major advantages is that wooden Venetian blinds are the best at blocking out light which become a must especially when someone needs to sleep during the day or when you have very strong streetlights close to your bedroom window.
Style and Integrity
Wooden Venetian blinds tend to bring a touch of class to your house or room. For instance when you have a luxurious or elegant style, wooden venetian blinds are the best option because plastic blinds may cheapen your interior decoration. Moreover, wood Venetian blinds can help maintain the integrity in a home that emphasizes wood decor such as a log house.
It is important to note that wooden Venetian blinds have many versatile styles coming in a wide range of stains and varnish levels that can match your paneled walls, furniture and hardwood floors. Another very important factor is that wooden blinds are easy to revamp or redecorate: if you are going to redecorate a room you can easily change their look by staining or re-varnishing wooden blinds in a different way rather than having to buy new ones.
Prone to Dust but Easily Cleaned
Although wood Venetian blinds are among the easiest blinds to clean, these tend to also be among the greatest collectors of dust and dirt. However, having said that, they are truly easier to clean than plastic ones because to clean the latter kind you have to either take them down or hold the blinds with one hand and wipe each slat with the other. Wooden blinds have the advantage of being solid and since their slats can be angled downwards, you can just wipe the slats with a damp cloth. Obviously you will need to dry them properly after cleaning because moisture may ruin them.
Made From Natural Material
Although wooden Venetian blinds go well in any room, in the end they are made from natural wood therefore shades may vary while grain patterns can sometimes be unpredictable. Moreover, their worst enemy is moisture or high humidity: in fact wood can warp when continuously exposed to such elements.
Wooden Venetian Blinds are among the best options for blocking light, and whilst being versatile and coming in a variety of styles and shades, they are also very easy to clean. Although they need very low maintenance they tend to collect more dust than ordinary blinds and their natural material dictate sound environmental awareness. However, wooden Venetian blinds are truly the best option for any room because they actually have a lot more pros than cons.
