Pros Vs. Cons Of Popcorn Ceilings
A popcorn ceiling.
A popcorn ceiling is a particular sort of treatment for ceilings that you can either paint or spray onto the surface in question. This type of work on ceilings was especially popular among customers in the 1980s. It has become popular again. When popcorn ceilings were first used they included asbestos that is very dangerous. However, nowadays the asbestos is gone. There are pros and cons to installing a popcorn ceiling in your home or place of work.
Pro: Hides any Problems with the Ceiling
A popcorn ceiling can cover up anything wrong with your ceiling. You can get a flat finish to your ceiling, but this will not hide any marks you have whereas popcorn ceiling will hide such problems as leaks, damage, and cracks. They are most definitely an attractive and nice option to smooth ceilings if you like the design of them.
Pro: Cheap to Install
It is very cheap and simple to install. If you paint a ceiling, you will find that it is vastly more expensive than this treatment. With this type of installation, you can just easily spray on the liquid to complete the job. Additionally, it will provide a reduction in noise as the texture of the ceiling will better absorb sound.
Con: Difficult to Paint
One disadvantage of a popcorn ceiling is that the texture used is very rough. This means that it is very hard to paint over when completed. You may need to take this into account before installing as you will no doubt have to redecorate at some point further down the line.
Con: Difficult to Repair
Performing repairs on popcorn ceilings can be extremely difficult. If the surface does get damaged at any point then this can make repairing it hard. This is the case if you get a leak or other ceiling damage such as a crack. It will, unfortunately, not be right after this and the entire ceiling will have to be treated again from the start if you are looking for a perfect ceiling.
Con: Cleaning is Difficult
As the surface of a popcorn ceiling is not smooth at all, this makes the cleaning of the surface very hard to do as you have to try and get into all the rough crevices that are there. For this reason alone, this sort of treatment is not really the right thing to install when it comes to bathrooms and kitchens. These rooms gather more dirt than others in the house. They should have smooth ceilings if possible in these rooms.
Con: Older Types Contain Asbestos
Some types of popcorn ceilings that were installed many years ago include asbestos which is of course, very dangerous. Modern installations do not contain this. Asbestos is now banned. If you think you may have a ceiling that contains asbestos before 1977, you should get this replaced as soon as possible.
