Real Brick vs. Faux Brick for Kitchen Backsplash
As part of home kitchen renovations, some may opt to choose between real or faux brick for the backsplash of their kitchen. The principal difference between the two types of brick is that real brick is obviously authentic whereas faux brick is just a replica. Real brick can be appropriate for some circumstances while faux brick can be appropriate for others. Here we shall go over the main differences between the two.
Faux Brick
Faux brick is quite easy and fast to install, and apart from this, it does not cost a lot of money. It is good for making a kitchen backsplash and there are various types of faux brick from which you can choose. Faux brick is also available in panel form and these panels simulate real brick in their thickness. However, molded plastic can be another constituent of faux brick and the cost of faux brick depends on the material as well.
If you decide to select faux brick for your kitchen backsplash, make sure that you choose faux brick of high quality. Such good quality faux brick has tiny holes in it and the moisture trapped inside the material will escape through these holes. In this way, water and humidity will not cause damage to your kitchen backsplash. Faux brick is ideal for construction projects as well.
Real Brick
On the other hand, real brick has less flexibility than faux brick. One drawback with real bricks is that it tends to retain moisture. Because of this, you will notice that, in time, the real brick will grow weaker and may even start to deteriorate. Unfortunately, real brick structures provide a good breeding ground for molds, especially if it is in constant contact with moisture. If not treated accordingly, it can later also produce an unpleasant smell.
The beauty of using real bricks is in the authentic, rustic look it projects. Although faux bricks are more convenient and much easier to maintain, nothing surpasses the real thing. There are still people who prefer to build fireplaces and walls from real brick rather than faux brick.
Comparison and Differences
A real brick and a faux brick differ from one another in many ways. It will take you a much shorter time to install a kitchen backsplash made from faux brick than one made from real brick. You can easily install a faux brick backsplash yourself while you may need to call in a professional if you intend to install real brick backsplashes.
Faux brick has longer durability than real brick, and you should use real brick in a moisture-free environment. For this reason, it is not ideal for a kitchen because you will be handling and cooking food there. The kitchen environment, at times, can be very humid and this can slowly damage the backsplash if it is made of real brick.
Generally speaking, faux brick is resistant both to moisture and fire, and manufacturers treat it with special chemicals at the factory when they produce it. Another difference between real and faux brick is that the color of real brick will fade away as time passes by, but the same will not happen to faux brick.
