Removing a Faucet and Drain from a Vanity Bathroom Sink
2-4 hours
Beginner
- 50-75
Removing a faucet and drain from a vanity bathroom sink may at first seem like a difficult task, but with patience and the right tools, most homeowners can complete this project in a single afternoon. More importantly, by reversing these steps, most homeowners can install a new faucet and drain. Cleaning out the remaining drain pipe at this point is also a very good idea.
Step 1 - Turn Off Water Supply
There are 2 shutoff valves located below each of the riser pipes to the bathroom vanity sink. Turn each of them off by turning their handles clockwise as tightly as they will go. Place a small bucket underneath the left riser and use a crescent wrench to turn the hex nut counterclockwise. Use the small bucket to catch the water in the riser. Repeat this procedure for the right riser.
Step 2 - Remove Pipe Risers
Using the faucet wrench, carefully get a grip on the end of the hex nut of the left pipe riser that attaches to the faucet and back it off in a counter-clockwise direction. Remove the riser, and repeat the procedure for the right riser.
Step 3 - Remove Faucet
Using either the faucet wrench or the crescent wrenches, remove the faucet retaining nut under the sink in a counter-clockwise direction. Removing these nuts will allow the faucet to be removed from the sink.
Step 4 - Remove Bathroom Sink Drain Pipes
Place a small bucket under the bathroom trap. Start at the bottom of the sink and loosen the upright pipe that attaches to the bathroom drain. Place a plumber's wrench on the pipe nut and another on the bathroom drain retaining nut. Remove the upright pipe nut in a counter-clockwise direction.
Catch the draining water from this pipe and the rest of the drain pipes as the water retained in these pipes can be somewhat smelly and spilling it can cause odor problems to remain in the vanity sink base. Place the plumber’s wrenches on the pipe resembling a semi-s shape. Remove the nuts for this pipe and catch the water that has been retained in it. Finally, there will be another pipe with the rest of the s shape that attaches to the permanent pipe that goes into the wall. Remove this pipe so that all the drain pipes are removed.
Step 5 - Preventive Maintenance
Run a snake down the permanent pipe that goes into the wall. Doing so will clean the pipe and prevent problems when the new drain pipes are installed. It is also a good idea to use a drain cleaner and deodorant or household cleaner to clean this remainder of the drain system.
