Replacing Bathroom Cabinets
cabinets
If you're remodeling or upgrading your bathroom, replacing your cabinets is a great way to boost your home’s value and give the space a fresh look. When it comes to remodeling your cabinetry, it seems like there is no end to the array of options that are available. Some people decide on a certain color or a favorite wood, but on should consider other factors such as doing the job yourself versus hiring a contractor and buying new cabinets versus refacing the current ones.
Determine Your Project
If your cabinets are still in good condition, and you like the current layout and storage , simply replacing the doors or hardware might be a great solution. On the other hand, if they have seen better days or you want to add more storage or counter space, completely remodeling may be the better choice.
Giving Your Cabinets a Face-lift
If you want a fresh look for your bathroom and you’re on a budget, there’s no need to gut all your cabinets. With a little elbow grease, you can totally change the look of your bathroom without throwing away good wood. Sanding the old finish will allow you to refinish the surface in a new color and texture. Replacing worn hardware with new decorative handles and hinges can breathe new life into your bathroom at a fraction of the cost.
Out With the Old
Sometimes cabinets are beyond repair and need to be replaced. The great thing about new cabinetry is that you can custom design the layout. If you are unsure that a layout that would work best for your application and needs, most cabinet retailers or builders offer design consultation when you purchase. They can help you narrow your choices and select custom features, such as doors, sinks, and toilets. They may also have designs, finishes, and hardware not typically available for do-it-yourselfers.
Do-It-Yourselfers
If you have the right tools and think you’re up to the task, you can save lots of money installing your own cabinetry. Floor cabinets and counter tops are easy to install requiring minimal home repair knowledge. More complicated designs and pieces that hang from the wall are best handled by an expert installer. If your bathroom project is more work than you want to tackle, check into one of the hire a cabinetry professional.
