Rewiring The Bathroom Fan Light
Removing the cover from a ceiling exhaust fan
  • 2-4 hours
  • Advanced
  • 25-75
Screwdriver
Voltage tester
Electrical tape
Double pole toggle switch
12-3 NM cable
Flashlight
Romex stripper
Wire stripper
Wire connectors
Screwdriver
Voltage tester
Electrical tape
12-3 NM cable
Flashlight
Romex stripper
Wire stripper
Wire connectors
The bathroom fan light is a standard fixture in most bathrooms; however, these fixtures waste a lot of electricity.
Among the ways to be more cost conscious about energy use is to install a bathroom fan light that allows you to have separate switches for the fan and the light so you can turn on only what you need to use.
Step 1 - Shut off the Power
At the switch box, turn off the circuit that controls the power to the existing bathroom light fan.
Step 2 - Remove the Switch
bathroom vanity
Remove the cover plate from the existing light switch and unscrew the switch. Pull the switch out of the box.
Step 3 - Test the Voltage
Use the voltage tester to ensure the electricity is off. Once you are sure the power is off, remove the wires from the switch box and then check the wires to make sure which set of wires goes to the fan and which set of wires goes to the light.
Step 4 - Disassemble the Unit
Remove the lens and light bulb from the light fixture. Loosen the fan assembly from its current location. Doing so may require going through your attic for access since many bathroom light fixtures are ceiling mounted between the joists.
Step 5 - Remove the Cover Plate and Wires
fan light
With the fan assembly free, remove the cover plate. Remove the wire connectors and separate the wires. Determine which leads go to the light and which ones go to the fan. Attach a small piece of tape to each set and label them for clarity.
Step 6 - Rewire the Fixture
Remove the feed wire from the fan connection box. Tie the new cable for the new fan switch to the existing feed wire. Strip approximately six-inches of the outer covering from each end of the new wire with the Romex strippers.
At the fan connector box, insert the new cable and tighten the clamp over a section of the cable that still has the outer covering on it.
With the wire strippers, remove approximately .75-inches from the ends of the individual wires.
Connect the white wire from the cable to the two white wires in the connection box. Connect the ground wires together.
Connect the black wire from the cable to either the light lead or the fan lead. Connect the red lead from the cable to the red wire. Tighten all of the connections and wrap each set of wires with electrical tape.
Step 7 - Reassemble
bathroom fan light
Reconnect the cover plate and replace the fan assembly. Reinstall the light bulb and lens. Loosen all of the terminals on the toggle switch. On the left side of the switch, connect the feed wire from the panel.
Connect the black wire going to the fan to one terminal and the red wire to the other terminal. Connect the white wires together. Connect the ground wires together.
Connect a spare piece of copper wire to make a small pigtail and then attach that pigtail to the grounding screw.
Wrap electrical tape around all of the terminals and push the wires back into the box. Screw the switch into place and attach the switch cover plate.
Turn the power back on at the switch box and try out your new fan and light switch.
Having the fan and light wired so they work independently can be an energy saving feature in a home. Before doing any rewiring project, make sure you have the power turned off for the circuit to insure safety.
