Running and Installing a Water Heater Gas Line
Working on a water heater gas line is usually recommended to be left to professionals due to the risks associated with the high flammability of gas. However, there is no reason that you should be stranded in times of urgency when you can undertake the process yourself with just a few precautions. A few handy tips can help you successfully complete this task without the help of professionals.
Tip 1: Analyze your Task
Success in any task is heavily dependent on successful planning. Therefore, the first step that you need to take is to analyze the extent of your task. If you need to get a gas connection, then you will usually have to obtain a license for it, so ensure that you have a licensed connection before you launch into installing the pipeline. Also, evaluate the total distance that you need to run a pipeline and judge if the line will be going through walls or bends. This evaluation will give you a clear idea of the task to be undertaken and the tools required to do so. Hence, make sure you have all the tools and material required available because you do not want to be stranded halfway into the task due to the unavailability of necessary tools.
Tip 2: Switch Off Main Gas Supply
Ensure that the main gas supply is switched off before you launch into any work on the gas line. This is the most important step that you need to undertake to ensure safety. Gas leakage can wreak havoc, and you do not want to pay such a heavy price for a simple mistake.
Tip 3: Clear the Work Area of Flammable Material
Gas is extremely flammable. Therefore, despite the precaution of switching off the main supply, you should ensure that no flames are brought into the work area. Special caution should be taken to ensure that smoking is strictly prohibited within a safe distance of the work station. Candles or other flames should be avoided for the same reason.
Tip 4: Be Vigilant to Discourage Future Leaks
When installing the gas line, you should always maintain high vigilance to ensure that there are no potential leaks. You should use a wrench to tightly screw the pipes to the joints and leave no loopholes. After installation, you should run satisfactory tests to ensure there is no leak. Apply soap and water to the gas line to detect leaks. In case of leaks, the solution would froth at the location of the leak.
 Tip 5: Use Insulated Pipes
An efficient way to conserve energy is to use insulated pipes for the water supply to reduce heat loss. This can help you save on your gas bills in the long run.
Tip 6: Think about the Future
It is always best to keep your future needs in mind during installation. As a result, it is preferred that you attach an additional port and put a stopper on it to compensate for any new future connection. This foresight can save you a fair amount of money in the future.
Find Trusted Professionals For Your Plumbing
