The Safety of Cooking on a Cracked Ceramic Cooktop
- Beginner
Ceramic cooktops are an attractive choice for many kitchens. They are generally safe to use but what if the ceramic cracks? Should a cracked cooktop still be used or should it be replaced?
General Kitchen Safety
Kitchen safety is important. Fire hazards and electrical shock are both major concerns. Burns should also be considered as these can be quite nasty when touching hot surfaces. Be sure that appliances are safe for use and that they are in proper working order. This will include the safety aspects of using cracked ceramic worktops.
Cracked Ceramic
So is it safe to use a ceramic cooktop that has cracked? The simple answer is no! If the cooktop has a crack in it, the homeowner should not use the cooktop at all. The smallest of cracks can cause dangerous problems. Electrical shock could occur if food or liquid were to spill over onto the crack. The use of cleaning solutions could be an important factor in electrocution as well.
It is best to be safe than sorry! If the cooktop is cracked, have the ceramic replaced. Another option is to replace the entire cooktop. New installations should also be checked for cracks to avoid the possibility of personal injury.
