Saltillo Tile Floor: Pros and Cons
Saltillo tile floor is a type of natural stone that is commonly used on patios. This type of tile has several advantages that make it ideal for many different applications, but it also has some drawbacks. Consider the following pros and cons of saltillo tile flooring to decide whether it is the right choice for you.
Outdoor Application
One of the advantages of saltillo tile is that it can be used outside, like on patios and around pools. Many tiles are not suitable for outdoor applications because they are not dense enough. Saltillo tile should not break during cold weather like ceramic tile would.
Customizable
Another advantage of using this type of flooring product is that it is customizable. You can install it in a number of different patterns and designs. This makes it a popular choice for those who want to get creative and make a floor that is one-of-a-kind.
Look
This type of tile provides you with a unique that you can not get from any other tile. Saltillo tile has an old-world, Mexican look that works very well in an outdoor area. It is a very classic look that will not likely go out of style.
Cost
You can generally get saltillo tile for $2 per square foot or less. In some cases, it might be more expensive, but it is still not among the most expensive options on the market. If you are going to install the tile yourself, it is a very economical flooring option.
Heat Absorption
One of the disadvantages of using saltillo tile is that it can absorb a great deal of heat. It will be difficult to walk on this type of tile barefoot when the sun has been on it for any amount of time. It tends to absorb the sunlight and become extremely hot to the touch. If you walk on this type of tile without protection, it may burn your feet.
High Maintenance
This type of tile also takes a great deal of regular maintenance to make it look good. You have to seal it every year in order to keep it from staining or absorbing water. Saltillo tile is porous, so you need to keep sealer on it at all times.
Scuffs
Another potential drawback of this type of tile is that it can scuff easily. It will show marks on the floor from regular foot traffic. It can also stain relatively easily compared to some other types of tile. This means that you have to be very careful when walking on it and wipe up your spills immediately.
Difficult to Install
If you are planning on installing saltillo tile yourself, it will most likely be a difficult job. It is difficult to grout saltillo because the grout can get into the pores of the tile. You also need to seal the tile before installing it.
