Shower Mildew Prevention
Squeegee
Sponge
Chlorine bleach
Oxygen bleach
Undiluted vinegar
Salt
Shower mildew is a fungus that grows on any moist, warm surface. Bathrooms provide the ideal environment for these minute organisms, which can cause several health problems such as allergies and bronchitis. In most bathrooms, mildew growth is especially pronounced on the walls and curtains in the shower area. By taking a few easy steps, you can prevent mildew formation in your shower.
Step 1 - Turn On the Bathroom Exhaust Fan Every Time You Shower
Mildew growth occurs in bathrooms that have poor air circulation. Every time you take a bath, turn on the exhaust fan in the bathroom. An exhaust fan removes the heat and moisture from inside and vents it outside your home. Ensure that the vents do not terminate outside your home. If the weather permits, you can also leave the windows open. If it is winter, ensure that the heater is turned on. This will also reduce moisture levels. Leave the exhaust fan on for a few more minutes after you have finished bathing. Close the windows and bathroom door after the bathroom is no longer warm and damp.
Step 2 - Wipe the Shower after a Bath
Keep a squeegee close to the shower. After you finish a bath, pour some water down the shower walls and then wipe them down with the squeegee. This will remove all the soap sum and accumulated water. Run the squeegee along the tub or shower floor as well, so that all the accumulated water flows down the drain. This will discourage the growth of mildew and speed up the process of drying. Use a sponge to collect excess water from the shower curtain, so that it can dry quickly. Spread out the shower curtain, keeping aside some space for the heat and moisture from the shower to escape.
Step 3 - Clean the Shower Regularly
Mold and mildew thrive in dirty conditions. If your shower is dirty and layered with soap scum and body oil, mildew will surely grow there. Make it a point to clean your shower once every week or two. The more often you clean your shower, the quicker and easier the task becomes. Chlorine bleach, oxygen bleach, and undiluted vinegar are great cleansers that remove hard water stains and prevent the buildup of mildew.
Step 4 - Clean Shower Curtain Regularly
Every time you clean the shower, clean the shower curtain as well. Buying a mildew resistant shower curtain will provide additional protection against mold and mildew. Wash the shower curtain in a bleach solution to remove all the germs and mildew. Hot water is beneficial to the process. To prevent mildew growth on the curtains, soak them in hot saltwater.
Step 5 - Avoid Clutter
Mildew loves cluttered, damp places. Avoid leaving soap or shampoo containers against the shower wall. Use a separate storage cabinet and dry everything before you store it away. Never leave damp towels or clothes lying around in the bathroom.
