Signs That You Need to Replace Your Overflow Tube
An overflow tube is something that has much to do with how well your toilet does or does not work. You must know what to look out for so that you can be completely sure about when it is time for you to replace the overflow tube on your toilet. Remember that having a basic idea of how your toilet works will allow you to know when something is wrong and how to fix it whenever the time comes. Even the most basic knowledge about your toilet will allow you to fix it in no time.
Basics
Basically, a toilet is made of a bowl and a tank. The overflow tube is in the tank of your toilet. There is a flush lever, which pulls on the chain whenever it is pushed. It will then cause the flush valve to be pulled. When the flush valve is pulled, a discharge hole at the bottom of the tank is exposed.
When the hole is exposed, water rushes into the toilet bowl. The water level of the tank lowers after a flush. The water leaves quickly and the tank begins to refill. As the tank refills, some of the water goes from your fill valve through the refill tube and in the overflow tube. The job of the overflow tube is to empty the water directly into your toilet bowl.
Location
The overflow tube is located below the refill tube. Whenever the refill tube pushes down on the overflow tube, water is siphoned from the tank, causing the fill valve to cycle on and off. The overflow tube cannot work properly without the refill tube, and the same can be said for the refill tube.
Too Little Water
If there is very little water in the toilet bowl, it could mean that the overflow tube or the refill tube is not working properly. They are in charge of the water that goes in and out of the toilet bowl. If they are not working properly, then the necessary amount of water will not reach the toilet bowl.
Too Much Water
The overflow tube is also necessary, so that you can make sure that the proper amount of water goes into the bowl. If the water does not know when to stop, it will keep going and eventually overflow. A common sign of a malfunctioning overflow tube is when water floods the toilet bowl. The overflow tube also directs the water where to go once the bowl itself has reached a certain level.
An overflow tube is something that is going to have a lot to do with how well your toilet does or does not work. Know what to look out for so that you can be completely sure about when it is time for you to replace the overflow tube on your toilet. Remember that basic knowledge of how your toilet works will allow you to know when something is wrong and how to fix it whenever the time comes.
