Slow-Blow Fuse vs Fast-Blow Fuse
There are various types of fuses: a slow-blow fuse, a fast-blow fuse, and a two-blade mini fuse. In today’s market, we find a fuse for every electronic need. If you are a beginner or you don’t have any experience whatsoever in electrical work, then you have to learn to distinguish among different types of fuses. Otherwise, you will eventually damage electronic equipment by installing an improper fuse. Therefore, it is always recommended that you install the same type of fuse originally used for a particular electronic circuit to prevent problems. Follow this guide to better understand the differences and common usages that exist between a slow-blow fuse and a fast-blow fuse.
The Definition of a Slow-Blow Fuse and a Fast-Blow Fuse
A slow-blow fuse is defined as a fuse that can tolerate high levels of voltage for a short period without shorting itself. This means that when a short or a sudden change in voltage occurs, a slow-blow fuse doesn’t burn immediately but withstands the high current for a short time, giving you the time to do what you were going to do or time to turn off the power source.
On the contrary, a fast-(or quick)blow fuse is a fuse that bursts instantly when high power voltage is passed through it. This fuse is the common fuse we find in much everyday electronic equipment.
The Uses for a Slow-Blow Fuse and a Fast-Blow Fuse
A slow-blow fuse is normally used in the motor industry because when you start an engine, at that moment, a high current of electricity is passed through the electronic circuit. Hence, the fuses could be blown. By using a slow-blow fuse, you bypass this problem because, as mentioned before, the slow blow fuses withstands that sudden high current flowing from the circuit, enabling the motor to start. Therefore, a slow-blow fuse is ideal in such circumstances.
By contrast, a fast-blow fuse is used in home appliances. Home appliances are sensitive to changes in the flow of electricity. Therefore, you need a prompt reaction to counter this problem, and this is where a fast-blow fuse comes in handy. The fast-blow fuse permits the home appliance to survive by instantly shorting itself instead of the electronic circuit.
    The Slow-Blow Fuse vs. the Fast-Blow Fuse
    As you can see, it’s not a matter of which fuse is better than the other but rather which is fuse best for a particular situation. These two kinds of fuses have different characteristics that suit your various electronic circumstances. As mentioned previously, making sure to use the same type of fuse when replacing a faulty fuse is critical to remember.
    Another important thing to remember is that if you are unable to differentiate between the two fuses, you need to ask for professional help. Otherwise, you will damage the electronic equipment, and, even more importantly, you could get electrocuted and suffer serious injury.
