Soapstone Sinks: Pros and Cons
Soapstone sinks are a popular option that has remained viable for many years. However, they are not perfect, and if you want to install one, you should know their good and bad features first.
Soapstone Advantages
Soapstone is a damage resistant material. If you install a sink made from soapstone, it will last for many years without damage. Soapstone sinks are very hard and dense. They resist all but the most serious abuse. With a soapstone sink, you will not have to worry about scratches, heat, or chemicals.Soapstone's resilient nature makes it easy to clean because the surface won't be damaged by abrasive cleaners.
Soapstone Disadvantages
Unfortunately, soapstone is not a perfect material. It requires regular application of mineral oil. If it is not kept sufficiently oiled, it will lose its distinctive color and appearance, turning a duller gray.
It is possible to chip soapstone with strong impacts. These problems are avoidable with proper maintenance and might discourage you from choosing a soapstone sink if you have your heart set on it. They are definite drawbacks that you should take into account before you make your final decision.
Find Trusted Professionals For Your Bathrooms
