Staying Healthy with a Water Ionizer
A water ionizer is a small device that you can connect to your kitchen faucet, where it ionizes the water flowing through it. Water ionizers use the process of electrolysis to separate the stream of tap water into an acidic stream and an alkaline stream. You can use the acidic water for bathing or watering plants, and consume the alkaline ionized water. Alkaline ionized water provides several health benefits when consumed.
High in Antioxidants
The process of ionization increases the antioxidant properties of the water. Ionized water has greater antioxidant properties than popular foods such as orange juice. It reduces the free radicals in the body, thereby fighting diseases of the heart, cancer and other grave ailments.
Lowers the Acidity in the Body
The process of ionization converts water to 2 different streams – one acidic and the other alkaline. The alkaline ionized water may be very effective in reducing the acidity in our bodies. Most of the modern diet consists of foods that cause an imbalance in the natural pH level of the human body. Ionized alkaline water is an effective remedy that can lower the acid content, thereby providing relief against acidity and digestive problems
Better at Hydrating the Body
Alkaline ionized water is assimilated much easier than tap water or even filtered water. This provides greater hydration for the body. You can also assimilate the minerals in ionized water easier.
Keeps Skin Look Younger
Because alkaline water is more hydrating, it reaches all the organs of the body quickly. Your skin will see a marked improvement with the regular consumption of alkaline ionized water.
Helps with Digestion
Alkaline ionized water aids the digestion process in the body. People who consume ionized water have lesser complaints related to the digestive system, such as gastric problems, bloating and acidity.
Aids in Detoxification
Alkaline ionized water is absorbed fast by the body, and thereby reduces constipation and other complaints. It is a valuable aid in the detoxification process for the body, and promotes better health and longevity, while at the same time reducing the occurrence of diseases.
Benefits of Acidic Ionized Water
In addition to the goodness of alkaline ionized water, the acidic residue also provides its own benefits.
Great for the Skin
The acidic ionized water must not be discarded, as it is great for external use. It is beneficial to the skin and hair, improving its glow and luster.
Helpful in Treating Rashes, Infection and Insect Bites
Acidic ionized water has antibacterial and anti-fungal properties. It is soothing to the skin and is effective for the reduction of symptoms such as rashes, itching, dry skin and dry scalp. It is also beneficial in the treatment of insect bites, and can reduce inflammation of the skin and acne seen in adolescents.
Reduces Severity of Mouth Sores and Ulcers
If you gargle acidic ionized water, you can find effective relief against sores, cankers and ulcers in the mouth. These painful conditions can be treated and their occurrence reduced with this easy remedy.
