Stone Siding vs Faux Stone Siding
20-80 hours
Intermediate
- 0-15,000
For generations, stone siding has graced innumerable buildings and architectural wonders. Stone lasts forever and is magnificent to look at. In recent years, faux stone siding has made an appearance in the market. It provides the looks of stone without the high cost. Before you decide on either of these materials, take a look at the pros and cons of each.
Stone Siding
Stone siding is manufactured from real rocks and stones harvested from the earth. The process of obtaining, transporting and finishing the stone contributes to very high costs. It is also not the most environmentally friendly approach because we are depleting the earth of its natural resources. Natural stone is very heavy. As a result, the effort put in by laborers is increased. This hikes the cost of installation and the time required for the whole process.
On the positive side, stone siding cannot be beaten in terms of durability and quality. It will last for hundreds of years. However, this also raises the question of whether the building will be around for that long. Stone siding is probably an appropriate choice for stately buildings that will be conserved well. There is no maintenance required and stone siding can be easily cleaned with a pressure washer.
Stone siding is impervious to harsh sunlight and ultraviolet rays. It will not peel, crack or fade in color. Even in the case of accidental cracks, the finish will still look beautiful because the entire material has the same look both inside and out. Stone siding is also resistant to moisture and humidity. It will form a strong barrier that protects the interior of a building from external elements. Very few materials can compare with stone siding when it comes to elegance and natural beauty.
Faux Stone Siding
Faux stone siding is an engineered material that mimics the look and feel of natural stone. There are several varieties of faux stone that are so authentic looking that most people can't tell the difference. The veneer applied on faux stone plays a large role in the overall appearance of the finish. Faux stone is highly durable and most varieties come with warranties of about 25 years. That being said, it certainly does not share the ageless quality of natural stone. Faux stone siding can be damaged under the high intensity of a pressure washer.
Faux stone siding is lightweight and easy to install. In fact, it can be installed by handy homeowners themselves. It is also much cheaper than natural stone siding. You can save the labor costs if you install it yourself. Compared to natural stone siding, the installation fees are much lower. This is because the material is so easy to carry around. Faux stone siding is also easy to clean and maintain. It is resistant to moisture, mold, mildew and most environmental conditions.
Faux stone siding is much more environmentally friendly. Most products can also be recycled and reused over time. Considering the cost benefits and superior durability of faux stone siding, many homeowners are beginning to choose it over original stone.
