Storm Door Hardware Installation
1-2 hours
Beginner
- 25-75
Storm door hardware is the most important part of installing your storm door. While assembling and installing the hardware is not a difficult thing to do, it is important that it is done correctly so your storm door works properly.
Step 1 - Install Door Handle and Locking Mechanism
Follow any specific instructions provided by the manufacturer for assembling and attaching the door handle and the lock mechanism.
The storm door hardware should include a template to help you know where to drill the pilot hole into the metal framework of the storm door. Once you have drilled the holes, insert the interior and exterior door handles, securing them with the screws provided.
Step 2 - Attach the Striker
Before attaching the striker plate to the doorjamb, mark where the striker will be going on the door jamb. The striker is the metal plate that allows the door to latch properly.
The location of the striker will depend on the position of the latch on the door. Once you have marked the location, install the striker. The center of the striker has a hole in where the latch will sit when the door is closed. Use a chisel to remove the wood in the hole, hollowing it out.
Step 3 - Assemble the Closer
The closer is the piece of storm door hardware that allows your door to open and close smoothly without whipping open or slamming shut.
Following any manufacturer’s instructions, put together the complete closer unit, including sliding the washer onto the closer. Once assembled, hold the closer level at the recommended height, marking on the door and door jamb the bracket location.
Once you have marked the correct spots, attach the closer to both the door and the door jamb, screwing it in at both locations.
Step 4 - Mount Safety Chains
The safety chain is what keeps the door from flying open and crashing into the outside of the house if it gets flung open. Attach the safety chain to the door and door frame per the manufacturer’s instruction.
Step 5 - Test the Installed Hardware
Once you have finished assembling and attaching the hardware, test out your storm door to make sure everything is in working order. Make sure the door is level and it opens and closes without any problems.
If the door slams shut or is hard to open, you will need to adjust the closer until the door opens and closes properly.
