Taking Care of Electric Tools: Basic Maintenance Tips
To ensure that your electric tools work when you need them to, you must take proper care of them. A good regimen of maintenance for your tools is one thing that you can do to make sure that the tool you need is working when you need it.
Clean out the Dust
To make sure that your electric tools are ready to go when you are, keep them clean and free of dust. The housing intake on your electric tools and the exhaust are especially important areas to keep clean. Take some time to clean out the dust every once in a while on your tools while they are sitting in storage.
Check the Cords
Look for wear and tear on the power cords on your electric tools. There can be damage to the insulation and you should keep an eye out for loose wires. This will ensure that your electric tool can get the power that it needs to function without an accident. Wipe the cords down to keep them from becoming damaged from oil and grease. The prongs on the cords should be examined as well. Make sure that the casing is intact and the prongs are not loose.
Oil Some Electric Tools
The electric tools in your toolbox that have a cutting surface should be lightly oiled to prevent rust. Examine the cutting surface for rust to make sure that your tools are kept in good condition.
Storing Your Tools
Keep your electric tools stored in their original cases and containers. This will keep them free of dust and dirt while they are not being used.
The proper care of your electric tools is the key to making sure that they last for many years.
Buying good quality power tools will also guarantee that they will last. Use the brand names that you know and trust when it is time to buy new power tools. A little research of consumer reviews will give you a good indication of which tool is the best for your use.
Only use your tools for the job they were intended. Using a tool to perform a task that it was not intended to do is a sure way to break it. Cutting tools should only be used to cut the materials they were designed to cut. Keep blades sharp and ready to go so that the tool does not have to work as hard to cut a single item.
