Terracotta Tile Floor vs Ceramic Tile Floor
If you are planning to install a new floor in your kitchen or bathroom, you will have to decide between different options such as a terracotta tile floor or a ceramic tile floor. Each type of floor comes with its own advantages and disadvantages. Because of this, it is important to learn the differences between ceramic and terracotta.
Durability
Ceramic tile is hard to beat in terms of durability. In fact, ceramic tile will almost always outlast your home as a whole, assuming they are of decent quality and installed correctly.
Terracotta is also a very durable material, but varies in quality from manufacturer to manufacturer. Thus it is important to do your homework and research the brand and quality of the terracotta tile before making a decision.
Installation
Ceramic tile is easy to install if you are a beginner and wish to do it yourself.
Terracotta tile installation is labor intensive and requires precision. You should consider hiring a professional if you are not experienced with installing this type of tile.
Cost
Terracotta tile and ceramic tile are practically interchangeable in cost. An expensive terracotta tile floor will cost more than a cheap ceramic floor, and vice versa. It is up to you to decide how much you want to spend.
Maintenance
Ceramic tile is often easier to clean. However, glazed terracotta tile can be wiped clean easily in most circumstances, and all types of tile are vulnerable to stains working their way into grout.
