The Benefits of Having a High-Flow Catalytic Converter
Those who are looking at the alternative of using a high-flow catalytic converter might be wondering about the benefits of going with this kind of technology for outfitting an exhaust system. High-flow catalytic converters have several potential benefits for vehicle owners. Those who install an aftermarket catalytic converter or “catcon” may do so for different reasons depending on what kind of vehicle they are driving.
What Is the Catalytic Converter?
The catalytic converter is a part of the newer fuel systems on modern vehicles that helps to regulate the exhaust. As such, it is part of the focus of new emissions standards for vehicles, and tied into a complex computerized engine system involving oxygen sensors that monitor the fuel mix for a vehicle.
New computerized fuel systems replace older traditional fuel systems that are featured in older cars where a carburetor was responsible for providing an air and fuel mix, and vehicle owners checked the fuel mix by inspecting spark plugs or through other hands-on mechanical observations.
Benefits of High-flow Catalytic Converters for Larger Vehicles
Experts point out that higher flow catalytic converters can be particularly useful for large or oversized vehicles like heavy-duty trucks. When a vehicle has a larger engine, a higher-flow catalytic converter can help provide adequate processing for the exhaust that comes out. According to many automotive professionals, mixes of exhaust and fuel system parts that are incompatible can prevent optimal performance for a vehicle.
Benefits of High-flow Catalytic Converters for Other Vehicles
Another benefit of an aftermarket high-flow catalytic converter is that it may help to alleviate some of the commonly reported problems with newer fuel systems.
In many vehicles, the catalytic converter becomes clogged over time, especially if other parts of the fuel system are not working perfectly. An improper fuel mix can compromise the catalytic converter and cause a “flag” in the engine computer. When catalytic converters are clogged, they will most likely require expensive replacement. A high-flow catalytic converter might stand a better chance of lasting a long time on the road.
Another potential benefit of aftermarket high-flow catalytic converters is that manufacturers are making these specialized exhaust parts with an eye towards the tighter emission controls in states like California. Depending on the state in which their vehicle is registered, car and truck owners might find a new high-flow catalytic converter helps them to comply with state requirements for carbon emissions. Many states have periodic mandatory carbon emissions inspections, where having a compliant fuel and exhaust system will help drivers save money.
Drivers who learn more about their fuel and exhaust systems can see how adding a high-flow catalytic converter might make sense for their particular vehicle. This kind of knowledge also comes in handy when the vehicle is experiencing issues related to the fuel system. The way many new cars are built, a “check engine light” indicates a wide range of issues, including both engine integrity failure and slight emissions problems. It sometimes takes extensive diagnostic work to find out what is actually happening with a fuel or exhaust system, and knowing how parts are tied together makes a big difference in the actions that the vehicle owner can take to get satisfactory diagnostics and repair.
High-flow catalytic converters have a multitude of benefits. Now, you can decided if it is right for your vehicle.
