The Pros and Cons Of Using Polyurethane Foam
Polyurethane foam is one of the most common materials used in the restoration of furniture. It is a popular material that presents you with a number of specific benefits. While there are some benefits involved, it is not without its drawbacks as well. Here are a few pros and cons of using polyurethane foam.
Pros
Soft- Polyurethane foam is one of the softest materials for furniture. It feels great when you sit on it, but is not very soft, so that you sink into the furniture. It makes a great choice when you value comfort in your furniture.
Durable- It is also more durable than many other materials. It will not typically wear out and can last for many years.
Cons
Chemicals- One of the big drawbacks with this material is that it emits chemicals that could be harmful to those with respiratory problems. It irritates the breathing and it reduces airflow.
Cost- While it is a durable and soft material, it is going to be more expensive than most other options. Polyurethane foam can cost more than some of the cheaper alternatives in the marketplace.
