The Pros and Cons of Vinyl Flooring
There are a number of reasons why vinyl flooring has long been amongst the most popular types of flooring. Not only is it relatively affordable compared to many other types of flooring, it can also look very authentic. In spite of this, vinyl flooring is a completely artificial product. It is easy to install and maintain. It is also highly durable. There are however, some drawbacks to consider when deciding what sort of floor to go for in your home.
Durability and Maintenance
Perhaps the most obvious advantage of vinyl flooring its high durability. It is often used in heavily trafficked areas such as kitchens, bathrooms or hallways. It stands up to this high traffic and it is easy to clean since you can simply wipe the surface as you would wipe a tiled surface. It is not prone to damage due to spillages, unlike carpet or wood. Maintaining vinyl flooring is cheap and easy and it lasts for a long time. To clean up mess, you can use a mop or use a broom.
Vinyl floors can be fragile in other respects. They are easy to scratch and damage done to a vinyl floor is difficult to repair. Repaired areas will never look the same, no matter how well the job was done.
Large Variety of Different Styles
Vinyl flooring comes in different styles, colors and designs. There is something suitable for just about every situation. A vinyl flooring finish is designed to imitate a natural wood floor or a tiled floor or anything else. You can find vinyl flooring that is suitable for living rooms, not only for bathrooms and utility rooms.
Noise Absorption
Another advantage of vinyl flooring is that it is resilient, absorbing any extra noise. This is particularly important in homes which have thin walls or ceilings, where noise can carry around to the other side of the house.
Installation
Installing a vinyl floor is a lot harder than it might look. The process is similar to installing a carpet. Since vinyl floors come in rolls, they have to be cut and joined in certain areas. Generally, they need to be installed by a professional. The surface preparation is also a labor intensive and time consuming. A badly installed vinyl floor can look terrible. The surface needs to be spotless, without any dust on it. If there is any dirt beneath the vinyl flooring when it is installed, it will form bumps and bubbles, destroying it completely.
Cost Effectiveness
One of the main reasons that people use vinyl flooring is its cost effectiveness. Vinyl flooring is very cheap to install; it is much cheaper than laminate flooring, wood flooring, tile flooring and even carpets.
Appearance
Vinyl flooring can look authentic. However, it cannot compete with the genuine article. Vinyl flooring will always be different from tiled flooring a wooden flooring in terms of appearance alone no matter how high quality it is.
