Tile Bathroom Floor Versus Linoleum in Bathrooms
Tile bathroom floors offer several benefits; however, some people prefer linoleum in their bathrooms for various reasons. Here are a few things to consider regarding tile and linoleum for a bathroom floor.
Durability
One of the big factors that you should consider for a bathroom floor is durability. Both options will present you with a very durable floor, but tile will last a little longer. It is hard, and it is not damaged easily. Linoleum can rip under certain circumstances.
Comfort
When it comes to comfort underfoot, linoleum is the better option. It is warmer and softer than a tile floor would be. It also provides you with a level surface, whereas tile will be uneven because of the grout joints.
Cleaning
Cleaning the bathroom floor is something else to consider. Linoleum is easy to mop. You can thoroughly clean it. With a tile floor, you have to worry about grout joints, which makes it a little tougher to clean. Dirt can be trapped in the gaps and cause problems. The grout can also be stained.
Find Trusted Professionals For Your Bathrooms
