Tile Floors vs. Concrete Floors
- Beginner
Tile floors have remained highly popular in home installations. Options abound on the market for flooring materials, just like roofing. The floor is a fundamental aspect of a room’s décor. You want to be sure that you do not have the wrong floor in any room of the house. It is important that you select a material that has high functional value as well as beauty. The right floor, carefully selected, will certainly boost your home's value. Below is an analysis of 2 popular materials, tile, and concrete.
Pros of Tile Floors
Tiles are available in a virtually unlimited array of colors, styles, shapes, patterns, and sizes. With tiles, you are certain to achieve whatever finished look you have in mind. A properly tiled floor makes a powerful statement. You need not call in a professional to install tiles. It is a project you can well undertake on your own. Tiles can be installed even on uneven surfaces. This gives homeowners flexibility in construction. A tiled floor is easy to maintain. Use a mild detergent and wet mop to clean spills and dirt off the floor. Stains will not develop on a tiled floor. This makes it a durable option in flooring. Tile floors are hygienic and allergen-free. They contribute to a cleaner and healthier home environment.
Cons of Tile Floors
Tiles feel cold on the feet. This can be quite uncomfortable, especially during cold weather. Repairs are a must when cracks or chips develop. If left unattended, it detracts from the beauty of your floor. Tiles get slippery when wet, especially the glossy variety. This can easily precipitate an accident. Crockery or glasses that accidentally fall onto a tiled floor are sure to break. Tiled floors can also be noisy. You may want to lay some rugs to dampen noise. However, this will obstruct the beauty of your tiled floor.
Pros of Concrete Floors
Concrete floors are easy to maintain. Simply sweep or clean with water whenever dirty. Be sure to mop the floor dry. Concrete does not heat up fast or cool quickly. This will save you money on energy bills. Concrete floors are a healthy choice. Allergens such as dust and pollen cannot set on a concrete floor. Concrete is an ideal solution if you or family members suffer from allergies. The tough mix of sand, stone, cement, and water makes concrete one of the most durable flooring materials. Once installed, it will last several years. Concrete is much more durable than tiles. When treated with a stain, you can enhance the beauty of your concrete floor.
Cons of Concrete Floors
Color choices for a concrete floor are not as unlimited as tiled flooring. Stained concrete will give you some colors to choose from, though not as unlimited as the tiled option. Specialized tools and knowledge are involved in the installation of concrete floors. This demands that a trained professional do the job. This will push up your costs. Periodic resealing must be undertaken to maintain the good condition of the floor.
