Toilet Flange Repair: Troubleshooting 5 Common Problems
Toilet flange repair is very useful because it will make it possible to improve the condition of your toilet. The flange is the part of the pipe which connects your toilet to the waste pipe. A damaged flange can cause a leaking toilet which isn't the nicest of sights.
Leaking Flange
The toilet flange is connected to the toilet by a wax ring. The wax ring seals the waste pipe so that the water can be flushed down the toilet. If the wax ring is damaged or broken, water will spill over the top of the toilet. A replacement wax bowl may be required to re-seal the toilet and prevent the toilet from leaking.
Length of Toilet Flange
The toilet flange needs to be the correct length so that the toilet can be secured properly. If the flange is too long or too short, then it can cause the toilet to leak. If a new floor has been installed in your bathroom, then it will often mean that the flange is too low in the floor. Extenders can be used to raise the height of the flange. If a floor has been removed, then it can also make the flange too high. The flange will either need to be reduced in height or a toilet plate can be used to raise the toilet up to the correct height.
Rocking Toilet
A rocking toilet can cause serious damage to the toilet flange. If the toilet is rocking, then you might need to replace the flange and stop it from rocking. Preventing the toilet from rocking will prevent the flange from breaking or becoming damaged. Tighten the toilet bolts to secure the toilet and stop it from rocking.
Cracked Flange
Toilet flanges are made out of cast iron or PVC. If the flange cracks, then this will allow water out of the toilet. Cracked flanges are more common with cast iron because they are very brittle. A cracked flange will need to be replaced by removing the toilet and bolting a new one into place. Alternatively, a reinforcer can be clamped over the flange pipe to strengthen it.
Clogged Flange
If the toilet flange or waste pipe is clogged, it can cause the toilet to back up. You may need to remove the toilet first before you can access the flange and get rid of the blockage. Repairing a clogged flange can be very difficult, depending upon exactly where the block is located.
Hiring a Professional Plumber
If you're having trouble finding the leak and repairing the toilet flange, then you shouldn't hesitate to contact a professional plumber. Hiring a plumber may seem like an unnecessary expense; however, it really will help to get the problem fixed as quickly as possible.
