Top 3 Ways to Remove Smells from Your RV
Among the many benefits of the RV is the opportunity to relax inside the living quarters, which is next to impossible when it's filled with noxious odors. To get the most out of your RV experience, you will need to learn the basics of odor removal. Odors in an RV come from a wide variety of sources. The holding tank can produce terrible odors, as can mold and mildew. Cooking and pet odors can permeate the interior carpeting and fabrics, making the smell difficult to get rid of.
1. Ventilation Is Key
Due to the size of the RV as compared to a home, bad odors are more pronounced. This problem is worsened when an RV remains closed and unused for long periods of time with the odor trapped inside. Ventillation is critical to removing odors and heat build-up inside the RV. Consider purchasing a ventilation product that is uniquely designed for the RV. These products allow you to leave windows and vents open all of the time, even during rain. Products range from a standard vent cover to a powerful fan and roof ventilator. These products can be easily found online or at many RV dealerships. They are worth the investment because they will keep the air circulating in and out of your RV.
2. Remove Nasty Holding Tank Odors
The RV holding tank is designed with a vent pipe that runs from the tank to the roof. The holding tank odors accumulate inside the tank and cannot escape, because there's no air pressure to force the gasses that produce the odors out of the vent pipe. This problem is exacerbated when traveling because the wind blows across the vent cap on the top of the roof, forcing air back down the vent pipe. The gasses are pushed back to the toilet whenever the air pressure outside the holding tank exceeds the air pressure inside the RV. To address this problem your best bet is to purchase a redesigned breathing system. You can attach the system to the top of the vent pipe, drawing the fumes out of the holding tank. One such product is RV-360, which works whether or not your RV is moving.
Another odor problem related to the holding tank is due to the use of chemicals. Some of the chemicals are dangerous to people or the septic system that the holding tank will be emptied into. To address this problem, consider using an environmentally friendly holding tank treatment product that can function both as a deoderizer and a cleaning agent. One such product is called Oxy-Kem, and there are others available
3. Pay Attention to Your Refrigerator
Remember that odors are trapped inside the RV in many places, such as carpeting and upholstery. Therefore a key component to odor control is prevention. Many RV users complain about odors that build up in the refrigerator when it's not in use. To prevent this problem, as part of your procedure for closing up your RV, defrost your freezer and clean the refrigerator completely. Leave the refrigerator doors open and put a box of baking soda or some charcoal inside it to absorb remaining odors. You can also follow these steps whenever you need to get rid of odors in your refrigerator in your home.
