Top 5 Environmentally Friendly Roofing Materials
If you care about the environment, then consider using roofing materials that are good for it. These types of roofing materials may cost a little more, but you will be saving the environment from having to deal with more waste or harsh manufacturing methods. There are dozens upon dozens of things to consider when purchasing roofing materials. The field can be thinned if you are in the market for green roofing materials. There are several that stand out above the rest, and that is what this article will focus on.
1. Metal Roofs
We often think about metal roofing materials being found in the country on barns and more rustic homes or businesses. Metal roofs are becoming more and more popular as people are becoming more conscious of their energy bills. A metal roof can save you a lot of money on heating and cooling costs because they do not absorb heat like other materials. You can have metal roofs made from copper, aluminum or steel, and some of them can last for up to 100 years. Once the roof has outlasted its years, it can be recycled. They are also very good for water catchment systems.
2. Reflective Coating
One of the best reasons to use a reflective coating on your roof is that it can be applied to asphalt, metal, and wood. It will reflect about 80 percent of the sun’s rays. Other materials will subsequently absorb that heat. The reflective coating can save you a lot of money over time and will mean a significant decrease in the natural resources that would have been used to heat and cool the home. You can apply reflective coating yourself, which can save you even more money.
3. Recycled Shingles
A regular shingle made from asphalt can last up to 20 years, and very rarely are such shingles recycled. This means recycled asphalt shingles can be expensive roofing materials to use. When you do use recycled shingles, they are made from items that have been reclaimed, which could have been in a landfill otherwise. Recycled shingles last up to 50 years, meaning you will not have to replace them for a long time. They are made by grinding up asphalt shingles that have been removed from homes or were left over from other job sites.
4. Slate and Clay
Clay and slate are both all-natural roofing materials that have been used on roofs for decades. They are not toxic and are very efficient with energy. Once it comes time to replace these tiles, they can be recycled without causing any pollutants from entering the air. Both of these materials can last for 100 years or longer if properly cared for.
5. Going Green
Green roofing materials are becoming more popular on large roofs, being more prevalent in urban areas. A membrane is installed on the roof to allow soil to be added on top of it. This means you can plant trees, flowers, and other plants. They absorb the heat as well as the moisture from the roof. They last about 40 years but insulate the home better than most other roofing materials.
