Top 5 Most Durable Roofing Materials
1 hours
Beginner
- 1
When shopping for new roofing materials there are a lot of factors to consider. You want to make sure the roofing materials are in your budget, do their job and you also need them to be durable. If you collect rainwater for filtering purposes or irrigation then that is also an important factor to consider. Durable roofing materials may cost more than other roofing materials at the onset, but they will save you money in the long run. They are often the most effective insulators, and they will last for many years, meaning you have to replace them less. Some materials are also usually virtually maintenance-free. The article below will share with you the most durable roofing materials.
Steel
Roofing materials made from steel are often coated will aluminum to act as a protective layer. One of the great things about steel roofing materials is that they often consist of recycled metal. You can choose the content of recycled materials for new materials. A steel roof absorbs sunlight differently than other roofing materials, which keeps the house cooler. The cost of the steel ranges from $80.00 to $350.00 per square foot, but metal roofing materials can last for at least 100 years.
Aluminum
You can choose aluminum roofing materials in various styles that mimic other roofing materials, like slate. You can buy them as bare aluminum as well and they also come in several colors. This material is incredibly light, so you will not have to reinforce the roof. They reflect sunlight like steel does to maintain a cool roof. You can find these made out of recycled material, and they are easily recycled. If you plan to collect rainwater from the roof, you need to have the aluminum coated with baked-on resin. Aluminum roofing materials will last anywhere between 50 and 100 years.
Ceramic
Ceramic and terra cotta are other names for roofing materials made from clay. They are found in many shapes and sizes. Once clay roofing materials are formed, they are dried in a kiln, essentially baking them. They increase the architectural appeal of the home and create the best rainwater. They will never discolor or fade and are resistant to extremely bad weather. They are fragile if stepped on, but besides that, they will last from 75 to 100 years.
Slate
Slate is a fine-grained rock that can be cut into roofing tiles. They produce good water quality, are very durable and completely natural. The process used to create them does not produce toxic chemicals. Slate will last between 100 and 200 years.
30-Year Asphalt
Glass is typically used over fiber that has been soaked by asphalt to act as an element of waterproofing. This will come in many colors and is one of the most inexpensive roofing materials offered. This material is easy to install and will last for 30-years.
