Troubleshooting 5 Common Sink Soap Dispenser Problems
Installing a sink soap dispenser can be a convenient and hygienic way to provide hand cleaning facilities. There are several reasons why your dispenser could be malfunctioning, and there are a number of do-it-yourself repairs for each possible issue. So, if you want to make sure soap is always available to you and your guests, be sure to check out this list of common problems and simple repairs to maintain your kitchen sink soap dispenser.
1. Solidified Soap
There will be occasions when liquid soap blocks the pump of the sink soap dispenser by getting into the wrong creases or crevices and solidifying there. When this occurs, the trigger and pump section of the dispenser will need to be removed by unscrewing it.
Leave the entire component to soak in hot water for approximately 15 minutes, then follow that by pumping water through it in the same way that you would with soap. When the water pumps through clear, reattach the piece to the body of the dispenser.
2. Trigger Fails to Lower
In the event that the trigger of the pump is pressed but it doesn’t move, you will find that there could be several causes. Some types of dispensers have the ability to be locked by twisting the top, which would render the trigger ineffective. So, start by checking to see if this is the case here.
Alternatively, a defect may have developed with the spring that makes up part of the mechanism. If you are able to access the spring, check to see whether it is properly aligned and put it back into place if it has become dislodged. Where this is not possible, the entire pump will need to be replaced.
3. Does Not Discharge Soap
When the sink soap dispenser is full but does not release any soap when the trigger of the pump is pressed, the problem may lie with the tube that gathers the soap.
Unscrew the pump so that it can be properly examined, and make sure that the tube is properly attached to the top. If the tube is not properly fitted, it will prevent the tube from pulling up the soap properly.
Another possible cause is damage to the tube itself, which may take the form of a hole or a split. When this is the case, either the tube or the entire pump will need to be replaced.
4. Trigger Remains Depressed
If the trigger of the sink soap dispenser does not come back up again after it has been pressed, the problem will lie with the spring in the mechanism. The spring is likely to have lost its tension or has been forced into a position that it should not be in. Unscrew the pump to determine whether you can gain access to the spring. If this is not the case, the pump will need to be replaced.
5. Pump Moves
In the event that the pump of the sink soap dispenser moves while it is in use, it is likely to be caused by incorrect installation. The pump section must be straight and properly screwed or pushed into place. If the dispenser is the type that makes use of a bottle of liquid soap, this needs to be fitted into the body of the casing properly.
Troubleshooting your sink soap dispenser problems is made easy with the help of this guide. Now you can wash your hands of these problems.
Common Sink Soap Dispenser Problems FAQ
Why does my sink soap dispenser not work?
Soap dispensers can stop working for several different reasons. Use trial and error to check for the common problems that usually make soap dispensers cease to function.
One problem that is easy to check is the soap itself. Did your dispenser stop working shortly after you added new soap to it?
Sometimes, the soap in the dispenser may be too thick. Test this theory by adding water to the soap to thin it and then test the dispenser.
If nothing will come out of the soap pump, it may be clogged. Fill a cup with very hot water and place the soap pump in here.
Press the pump to push the water through and see if this releases the clog.
The dispenser itself may also have a leak. This affects the pressure and can cause the dispenser to fail.
Check for a leak by placing dry hands around the dispenser. Touch every part of it you can reach and check for moisture.
Some part of the dispenser may also be broken. Visually examine it and the pump to see if you can detect any visible signs of damage.
How do you fix a leaky kitchen sink soap dispenser?
If your dispenser is leaking anywhere, try cleaning the pump mechanism. Soak the entire pump in hot water and depress the pump several times to push water through it.
Next, place the pump back in the dispenser. Check the dispenser everywhere to make sure all connections are secured and that everything is fitting together tightly.
This may help stop the leaks. Remember to clean the pump regularly to avoid clogs that can create leaks.
How do I fix my soap dispenser pump?
If your soap dispenser is not working because the pump is clogged, this is an easy problem to solve with hot water. But if the spring inside the mechanism has become worn out or damaged, you may need to replace the entire pump.
How do you clean a clogged soap dispenser?
If you have a stubborn clog in a soap dispenser that cannot be dispelled with hot water, try adding a little vinegar to the water and flush out the pump using this solution. You can also try using a toothpick to push a clog out of the pump.
Can you replace a soap dispenser?
If your soap dispenser is past the point of repair, it can be replaced. In fact, this is a relatively simple DIY.
Soap dispensers come with the washers you need to install them where the former dispenser was sitting on the sink. All you really need to perform this task is a pair of pliers or a wrench.
