Troubleshooting Your FM Radio Transmitter
The FM radio transmitter in a car is perfect for people who want to hear songs playing on an mp3 player, iPod, and any other audio device wirelessly on a car radio. The transmitter changes the output sound from these audio devices into radio signals that can be tuned into on any radio player. Sometimes, the transmitter may not work due to some technical problems or incorrect installations. Here are some ways to troubleshoot an FM radio transmitter.
The FM Radio Transmitter Does Not Function Correctly
If the transmitter does not function properly, check if the wires and cables are installed correctly, connected to the right connections, and secured tightly in place. Check the device's manual to make sure that the device is installed properly and tighten all necessary connections.
It Does Not Turn On
Many factors may contribute to this problem. FM radio transmitters can be powered in different ways. Some are designed to be connected to an AC power source. Some are powered by AA or AAA batteries, while some are powered by a cigarette lighter plug. If the transmitter is powered by AC power, make sure that the AC adapter is working properly and check if the transmitter is connected to the power source securely. If the transmitter requires batteries, the batteries may be dead. If so, replace the batteries. This should solve the problem. If the transmitter is powered by a cigarette lighter plug, make sure that the cigarette lighter plug is working fine.
Unclear Music Output or Distorted Radio Signal
Lower the volume of the audio player and crank up the volume of the radio transmitter. This should improve the quality of sound being transmitted through the radio. Sometimes, the radio frequency is distorted due to some interference coming from other radio frequencies. Try switching to another radio frequency to check if it solves the problem. Sometimes, signals from other radio stations overpower the signals coming from a personal FM radio transmitter. The simple solution to this problem is to switch to a frequency that is not currently used by anyone else.
If none of the above helps make the signal clear enough, check the antenna to find out if it is installed properly. If a hissing sound is heard, this is a sign that the car is not positioned in a desirable area where radio signals can be picked up. Wait until the car is in a suitable location and the signal is strengthened, then try again. To enhance the signal reception, make use of directional FM antennas that can be installed to both the transmitter and the car. Make use of extendable antennas for better quality signal reception.
Radio Output Volume is too Loud
If the output volume of the transmitter is too loud even when it is not in use, lower the volume control from the radio transmitter. When you are ready to use the FM radio transmitter again, turn up the volume.
