Types of Tin Roofing
corrugated tin roofing
Longevity and weather resistance are the two most valuable attributes that tin roofing has. The capacity of tin roofing to resist the elements of Mother Nature is really superior, and it can even last a lifetime. This is because tin roofing is actually made up of rolled steel and is just coated with tin. Tin is a metal that does not corrode, even with constant contact with rainwater, making it durable. So, what are the types of tin roofing?
Corrugated Tin Roofing
As the name implies, these are ridged, grooved, or wavy metal sheets for your roofs. It used to be that these roofs were usually used for industrial purposes or barns. Lately, there seems to be a market for these corrugated sheets as roofing materials of residences, giving homes a different and textured-looking roof.
Standing Seam Design
This type of roofing design is produced when metal panels are vertically laid side by side. Each of the metal sheets is connected at the ends where the overlapping seam or lock is formed. The fastening of the metal sheets is made possible by nails on screws that are kept hidden from view because of the overlap of the edges of the metal sheets.
