10 Kinds of Levels and How to Use Them
Written by
Doityourself Staff
on Sep 14, 2011
Reviewed by
on Aug 14, 2019
Levels Safety Tips
- Never drop a level. It is a precision instrument and the impact could jeopardize the integrity of the tool.
- Always keep a level in its protective case if it has one.
1. Carpenter's Level
- Tool that employs bubble vials positioned in the center and both ends to check vertical and horizontal surfaces for level or plumb.
- Made of either hardwood with brass binding, metal (aluminum, magnesium) or high-impact plastic.
- Typically 24" to 48" long, but some models (generally mason’s levels) are longer and can be up to 72” in length.
- Some models include split level or graduated vials that have two sets of lines, with the outside line representing a two percent grade that conforms to the slope required for gutters and waste lines to drain properly.
- Some models include electronic features to calculate angles on sloped surfaces (roof pitches, stair slopes and drainage angles) and display reading in degrees, percent slope or inches per feet (rise/run).
2. Torpedo Level
![torpedo level]()
- Usually 9" long and 1” wide, it is used for obtaining readings in close quarters where a typical carpenter’s level won’t fit.
- Because of its compact size, mechanics, plumbers, electricians, hobbyists, and homeowners often choose torpedo levels.
- Enhancement features include magnetized models and models incorporating a battery-operated light for working in dark areas
3. Plumb Bob
- A small, tapered, pointed weight suspended from string or cord used to measure true vertical plumb or depth.
- Commonly used in construction and framing.
- Many chalk line reels can also be used as plumb bobs, hanging the tool from its string.
4. Line Level
- Used for checking level over distances, such as when installing a patio, floor or a suspended ceiling, and when there is no flat surface available.
- Generally attached to a string stretched between two points, allowing the user to make an accurate height comparison between the two points.
5. Circular Level
- Circular in shape, this tool is used for leveling flat surfaces over a 360 degree plane, such as table tops and appliances.
- Also called Bull’s Eye or Surface Level.
- When a bubble appears in the center of circular vial, piece is level.
6. Angle Level
- Locates angles and pitches (slopes) from 0 to 90 degrees.
- Commonly used when installing drain lines to check for proper fall of pipe.
- Generally reads slope or pitch with inches per foot rise scale.
7. Laser Level
![laser level]()
- Also called laser chalk lines, they are used to level and provide reference lines for hanging pictures, tile work, etc.
- New features for electronic levels include having preset angles commonly used in construction, a self-leveling feature, and offering a graphical display that tells the user the direction and extent to rotate toward level or plumb.
- Accessories include a variety of mounting devices such as clamps and magnetic mounts that make setup and use easier and more convenient.
8. Post Level
- Used to set and plumb posts and columns
- Attaches to post and displays level in two directions.
- Also available in magnetic models for positioning waste lines in plumbing applications
9. Rotary Laser Level
- Most units come with either a self leveling or manual leveling base as well as floor and wall mounts.
- Generally accurate to 1/4 ” at 100’ for manual leveling units and 1/8” at 100’ for self-leveling units
10. Laser Plumb Line
- A self-leveling device that projects a vertical laser line onto any surface
- 2. The laser line is always visible because it is not covered up with a pencil mark and it is not affected by wind like a plumb bob
Courtesy of NRHA.org
