Wiring Projects
Featured Articles
They're only useful if you know what they mean.
They can handle two 120-volt circuits or one 240-volt.
Establish a safe distance.
Working with outdated parts can be risky.
Here's how to troubleshoot this outlet surprise.
A faulty ground is a serious risk.
Electric power is the most dangerous aspect of most homes.
Choosing the right materials can be confusing.
Learn why you should invest in a time delay fuse.
The main difference is that one has a neutral wire.
A broken fuse can be a safety hazard.
Changing out the electrical switches in your home is an empowering DIY project for nearly any homeowner. Here is a step-by-step tutorial.
How long can your 12 gauge electrical wire be?
Receptacle testers tell you what's going on with an outlet.
Security lights can only help protect your home when they’re working properly. Troubleshoot yours to find the fix you need.
They're best for simple, low-power devices.
Learn how to replace a generator's rear-end bearing.
A well organized kitchen makes food more fun.
Oxidization of wires can impair their conductivity.
Electrical wires left alone too long in the elements can corrode.
If you're noticing your GFCI outlet tripping more frequently, it could be one of three common problems. Check it out to avoid further problems.
Ground copper wire is commonly found in electrical components.
Understanding your wiring color codes is critical.
