Using Swiss Chard as a Companion Plant
Swiss chard leaves on a wooden table.
Many gardeners will use plants, like Swiss Chard, as companion plants to help make their vegetable gardens healthier and free from pests. There are several plant species that have natural substances in their roots, leaves, and flowers that help repel harmful insects, or attract helpful ones.
Swiss Chard
Chard is a green leafy vegetable that is an excellent source of vitamins and minerals. They are sometimes called an alternative to spinach. Swiss Chard is also easier to grow than spinach as they can withstand higher temperatures and even water shortages. They are very good growing as food, but they are also grown as a beautiful ornamental plant.
Companion Planting Is Important
Gardeners have come to realize, through experimentation and experience, that companion planting is a very important part of creating a beautiful landscape or thriving garden. In fact, with companion planting you are taking a lot of the human involvement out of the equation and replacing it with the natural order of things. Some plants just work better with others and create natural protection and enrichment.
Less Chemicals
Plants like the Swiss chard actually help repel many of the harmful insects and attract beneficial ones. This cuts out the need for using pesticides, insecticides, and harmful fertilizers in your garden or landscape. Using plants that are native to the area are the most beneficial as they already attract the right insects.
Swiss Chard as Companion Plant
Swiss chard plants do make a very good companion plant for several different varieties of vegetables. The one thing to keep in mind is that Swiss chard can get to be pretty big when fully matured and ready to reap. They can crowd out smaller plants if planted too closely.
Companion Plans for Swiss Chard
Both vegetables and flowers will benefit from growing Swiss chard with them. Tomatoes do very well around Swiss chard as do roses. The best plants for the Swiss chard to grow with, however, would be beans, anything in the cabbage family, and onions. They are mutually beneficial to each other. Because the Swiss chard will grow larger, it will keep in the humidity, and the moisture, so the other plants will benefit from the moist ground.
Plants To Keep Away From Swiss Chard
While there are very good reasons to use Swiss chard as a companion plant for a wide range of vegetables and flowers, there are those that you should keep them away from. Potatoes are not a good companion plant, as well as corn, cucumbers, melons, or herbs. They will either combat the chard for the nutrients in the soil, or they will invite pests that will harm the chard.
Remember that companion planting should be beneficial to both types of plants or vegetables that you are planting. If only one will benefit, it will be to the detriment of the other. Companion planting is a great idea when you need to grow vegetables in containers or have small areas from which to grow a garden. Experimentation is a good way to find which plants work good together. One good rule of thumb to follow, however, is that if they are in the same family, they will benefit each other.
