Make Your Own Utensil Holder
A utensil holder is any device that is used to sort and store kitchen utensils for easy retrieval when they are needed. Since stock utensil holders often fail to do the job, it is sometimes best for a do-it-yourselfer to create a customized version. This multi-step job is one that can pay off with a utensil holder that will work for items found in most kitchens.
Step 1 – Brainstorm Utensil Holder Materials
A utensil holder can technically be made out of a variety of materials. Some of the options include:
  • Coffee or other similar cans, which can be ideal for countertop utensil holders;
  • Wood, which can be used to create utensil holders to place inside cabinets;
  • Plastic, ready-made buckets or pot holders can be divided to store items.
Step 2 – Consider the Items That Will Go in the Holder
It is not necessary for a utensil holder to store all kitchen utensils. Generally, these handy devices are used to keep the most used utensils in a single, easy-to-find location. To pick what should go in and what can stay out, sort through utensils and pull out those that are used the most. Once this is done, examine the utensils for size, shape and any unusual features that might require special storage.
Step 3 – Create the Design
Grab a few pieces of paper, a measuring tape and a pencil. Brainstorm some potential designs. A large can for example, can be subdivided using heavy wire mesh or thin wooden sheeting to hold a limited number of utensils. A wooden box with dividers can be created to either set on a counter or fit on a shelf. Plastic buckets, too, can be subdivided to hold utensils. While dividers are not necessary for a design, they can make organization of like utensils easier.
To make sure a design will actually work, do measure the utensils before sketching the final draft. Buckets and cans should be deep enough to hold the tallest utensils. Wood designs, made completely from scratch, should be customized to fit the collection and even allow for some additions down the road.
Step 4 – Build the Utensil Holder
Once a plan is in place, gather materials and put the utensil holder together. Take some time and make sure the dividers are properly spaced and that the end result is sturdy enough to keep up with a busy kitchen.
Step 5 – Finishing Touches
The final touches will depend on how creative the end design is meant to be. Cans and plastic buckets can be finished off with fabric to blend more readily into a kitchen. Wooden designs can be stained or painted.
Creating a customized utensil holder can take the hassles out of working in a kitchen. When all major utensils are easy to find, cooking is a much more enjoyable task.
