Vinyl vs Wood Beadboard
Many people are forced to make a decision between vinyl and wood beadboard for their homes. Both types of material can present you with a number of advantages and disadvantages. If you are trying to decide between vinyl or wood beadboard, here are a few things to consider about each.
Cost
One thing to consider about these two products is the cost involved. Wood beadboard is almost always going to be less expensive than a vinyl beadboard. Vinyl is not a natural product and requires a lot more processing to make. Therefore, it will cost you a little bit more to get your hands on.
Availability
Another thing to consider is the availability of both products. Wood beadboard is fairly easy to get and you should be able to get it at any lumber yard around. However, vinyl beadboard is not something that you can usually go and pick up on a moment's notice. You will usually have to special order vinyl beadboard, so it will require a little bit of planning.
Maintenance
You should also consider the level of maintenance that will be required for each product. Since wood is a natural product, it can deteriorate over time and will require painting. Vinyl does not require painting and it can be easily cleaned compared to wood.
