Well Water Problems: Why Does the Water Appear Cloudy When Initially Pumped?
Common well water problems include the appearance of cloudy water. There are a variety of issues that could cause cloudy water. It is important to investigate the situation in order to address the problem correctly and to be certain that your well water is safe for household use. Perform these tasks to determine the source of your cloudy water.
Step 1 - Look for Pump or Filter Issues
Fill a drinking glass with well water. Allow the water to sit for a few moments. If the water comes from the tap cloudy then clears after it is allowed to settle, your pump or water filter may be experiencing problems.
Step 2 - Check for Residue in the Well
The presence of dirt, silt, or rust residue in your system can cloud your well water. If these particles are in your system, they will eventually be pumped along with the water through your pipes and out of your faucet.
Step 3 - Look at Excess Surface Water
Surface water that seeps into your well is usually benign; however, if there any excess amount getting into your system, you could experience cloudy water. Large amounts of rainfall could cause excess surface water problems.
Step 4 - Keep up with Testing and Maintenance
Ensure that your well water is safe through regular testing. Have your water privately tested for any bacterial contaminants such as E. Coli. Be sure your well water filtering system is operating properly. Replace your water filter on a regular basis.
By taking these steps you should be able to diagnose and prevent well water problems.
