What are advantages of a rubber paver patio?
Rubber paver patios, while they likely will fade overtime, are the answer to the prayers of home or building-owners in the mid-latitude regions because of the simple fact that they are rubber and they do not suffer from the cold-thaw problems that break up stamped concrete patios and they do not need the special types of handling that flagstone-based patios need as flagstones can shatter into very sharp shards if hit incorrectly. Pavers, on the hand, are interlocking, so there's no movement and they are non-slip. Plus they make use of many tires that would otherwise be thrown away in large tire graveyards around the country.
