What are French Patio Doors?
French doors opening onto a porch.
  • 8 hours
  • 2500
French patio doors are a pair of tall double doors with long window panels inset in the middle of each door. They are sometimes called French windows or casement doors.
Design
French patio doors will generally stretch from floor to ceiling height, so they will need to have a weather strip at the bottom to stop rainwater and drafts from coming through. They are designed so the long glass panes, often known as lights, will let in as much natural light into your home as possible.
French Doors in the Home
white French doors opening into a living room
French doors are often used to open up a room onto a patio or balcony. However, they are often used inside the home too to link adjoining rooms and create a feeling of space and airiness. This is more desirable than having a solid wall.
Modern French Doors
The French door style has been adapted to give many options for your home. Common elements of French doors are primarily glass doors including a gridded layout, but also come with frosted glass, mirrored panes, and sometimes even as pocket doors. If you are purchasing French doors, you will find that they are available in a variety of designs that may suit you if you are lacking space in your house, rather than a simple inward or outward motion.
