What are the Advantages of Using Glazed Brick?
Glazed brick is a type of brick that has a ceramic coating fused to its exterior surface. These bricks are typically fired twice, once for the creation of the brick itself and the second time to fuse the ceramic coating on the brick’s surface. Glazed brick is an attractive, durable option that finds use in interior and exterior constructions.
Glazed brick has been in use in construction for many years. It is popular because of the several varied advantages it can provide. It is durable, attractive and can provide a unique look to any building.
Durability
Glazed bricks provide superior durability and strength, which far exceeds that of normal bricks. These bricks last in good condition over the lifespan of most buildings. High degree of resistance to fire is another major asset of glazed bricks. Most of these products have exceptionally good fire ratings, which makes them superior from the safety aspect. It is also safe for the health of the occupants of the building because it does not emit any toxic fumes and does not degenerate with time. The tough satiny finish on glazed bricks makes them highly impervious to graffiti and vandalism. As a result, they are widely used in business and educational institutions.
Versatility
Glazed bricks match the look of the other existing components of a building, so they are often used in renovation projects or to enhance the look of a building. These bricks are available in many sizes, shapes, colors and finishes such as matte or glossy. This provides every buyer with a choice that matches their requirements. Glazed bricks are tough enough to withstand any climatic condition. They are also better suited to harsh climates that see extremes of temperature, because they are resistant to frost and also remain unaffected by extremely hot temperatures. Freeze and thaw cycles in colder regions may affect other construction materials in a negative way, but glazed bricks remain largely impervious.
Ease of Maintenance
You can easily clean glazed bricks with mild detergent and water. Glazed bricks require minimal maintenance and care, which adds to their popularity as a building material. Glazed bricks have a high degree of resistance to most chemicals. They are also tough and impervious to heavy loads and impact. This makes them ideal choices for high traffic areas, whether in the interior or exterior of a building. Because they are fired at extremely high temperatures, glazed bricks are impervious to color fading. They maintain their aesthetic appeal for a very long time and are also resistant to staining.
    Disadvantages of Glazed Brick
    One of the disadvantages of glazed bricks is the extremely high temperature required for processing. The double firing process is also not very good for energy conservation. Glazed bricks are also quite expensive and may not suit the budget of every building project. The heaviness of these bricks requires the building of a very secure foundation that will not be affected by the weight on top.
