Wallpaper
Featured Articles
Give your home a bold look this year!
Wallpaper is back! Make it easy with our tips on application.
Remove wallpaper in five steps!
Removing wallpaper can be a messy task.
Stripping wallpaper isn't fun—at least it's not hard.
Interior décor always changes, but things like wallpaper borders can be hard to remove. Try these steps to make the job a little easier.
It's not just a cut and paste job.
Wallpaper is steadily making a comeback.
Wallpaper is one of those products that has stood the test of time, but can be a pain to remove.
Wallpaper can create an instant change to a room.
Take wall surfaces to a new level of texture and color.
Wallpaper repair saves the time and money of replacement.
The trick is liquid fabric softener.
Wallpaper has been around forever, but now there is finally a way to put the glue onto the wall instead of each sheet of wallpaper.
Wallpaper problems are best solved during installation.
Knowing where to start hanging wallpaper can be tricky.
Skip the expensive wood and replace it with wallpaper.
When wallpaper is new and in good shape it can add a lot of depth, richness and character to a room.
Paint is great, but a wallcovering is better. There are many reasons to back this theory up.
The task of stripping wallpaper is a difficult messy task.
When the trends change, expose your wood.
If wallpaper was removed from your walls, you may need to repair the damaged drywall.
Wallpaper glue can take time to remove, but the tools needed are pretty simple.
