The Pros and Cons of a Slab Foundation
Among many types of foundation used for construction of a building, a slab foundation is no longer as popular as it once was. There are more cons associated with this type of foundation than pros.
What Are Slab Foundations?
A slab foundation is a foundation that is made of a concrete slab. Slab foundations are often laid over soil-based areas. They provide an easy method of setting a base foundation by simply pouring the slab foundation mixture over the area and leaving it to harden. Slab foundations can also be purchased and laid in concrete blocks. They offer a quick, cheap, and easy method of laying a foundation.
What Are the Pros of Slab Foundations?
Slab foundation can be constructed at a much cheaper cost than other kinds of foundations. As the cost of the foundation is cheaper, it also reduces the cost of purchasing a house made with a slab foundation. Slab foundations offer the option of adding additional space, as they are easily extended. Slab foundations are very strong and hard; they offer strong flooring material that is unlikely to break. These foundations are very easy to lay by simply placing the concrete blocks down or pouring the slab over the designated area.
What Are the Cons of Slab Foundations?
Due to installation techniques, electrical systems may be difficult to access when issues arise because they are often installed below the slab foundations. The floor is very hard. Although they offer stability, they can be uncomfortable. A slab foundation home can be very cold due to the lack of thermal cover and heat containment. These foundation also lack water resistance, so they can get very damp. Cracks also easily occur in slab due to the hardness of the material.
