What is Organic Waste?
Vegetable waste in the sink.
Organic waste is material that is biodegradable and comes from either a plant or an animal. Organic waste is usually broken down by other organisms over time and may also be referred to as wet waste. Most of the time, it is made up of vegetable and fruit debris, paper, bones, and human waste which quickly disintegrates.
In an effort to keep the environment clean and safe, organic waste is preferred over items that can damage the earth and that do not disintegrate. For example, plastic shopping bags and plastic water bottles take a long time to disintegrate and leave their imprint in their wake.
Composting
Many homeowners create their own composting from their organic waste by adding an agent such as animal manure or yard waste including grass clippings leaves, twigs, and branches to help bring vital nutrients back to the soil. Composting on a regular basis also helps keep trash landfills and other planet waste at bay.
Experts suggest that in order to compost correctly and efficiently, you need to use nitrogen, oxygen, water, and carbon. The ratio of each depends on where you live in the country, the weather conditions, and the amount of organic waste you have.
By mixing these ingredients, the result is usually a dark, crumbled mixture comprised of organic decaying material. Check with gardening or landscape professionals at home improvement stores on how to best prepare and maintain composting at home.
Whether you decide to compost yourself or take your organic matter elsewhere, know that you will be doing your part to help the environment be a safer, cleaner place for everyone.
Here are some typical organic waste categories that can be found inside and outside your home.
1. Garden Waste
True organic waste can be just about anything that comes directly from your garden such as plants, flowers, grass clippings, weeds, and leaves.
2. Kitchen Debris
Items that are considered to be organic waste from the realm of the kitchen include egg shells and vegetable and fruit peels like orange rinds, apple skins, tomatoes, and cucumber skins. Anything that you might use to make a salad would qualify as organic waste.
3. Cooked Foods
Cooked leftovers and meats that will eventually shrivel up and recede into the earth such as cold cuts, browned meats, and even bones are organic waste.
4. Paper Products
Paper towels, cardboard, and writing paper are all considered to be biodegradable and safe for the environment once they are broken down. Paper items such as these are often considered to be good composting materials because they break down rapidly and efficiently.
5. Human and Animal Waste
Human waste, manure, sewage, and even waste from animal slaughter are all forms of biodegradable waste materials. Animal manure can usually be purchased in large quantities at home and garden centers.
Additional Info
Call your local city offices for help learning more about composting and ways to remove your organic waste. Many cities offer seminars, classes, or courses on the topic that could be helpful in learning how to be green at home.
