The Best Way to Cut Fiberglass Bathroom Wall Panels
Fiberglass bathroom wall paneling can be tricky to cut. The biggest issue is to avoid splintering and cracking as you cut.
Quick Tips
Almost any type of saw can be used, including a hand saw, circular saw, or jig saw. Use a new saw blade with fine teeth. Mark the edge with a straight line of masking tape. Use a C-clamp to hold the panel still while you are cutting it.
