What is Trisodium Phosphate or TSP Cleaner?
Pile of TSP cleaner
Trisodium phosphate is also known as TSP and is an agent that is primarily used for cleaning. It is also an additive in food as well as a stain remover. The look of this agent is white and it is made from solid crystals. They dissolve in water and create a solution that is alkaline in nature. It can also be found in white powder form in some cases. It was regularly used in soaps and detergents in the past and is very popular.
Uses
cleaning supplies
The main use for trisodium phosphate is in agents needed for cleaning. As it is mainly alkaline, this means that it is fantastic for cleaning grease and oil stains amongst others. It is used in combination with other detergents and is great for cleaning clothes in particular. However, it is also used for cleaning concrete driveways and paths. The fact that it is so versatile means that it is purchased often. Additionally this substance can also be used for joints in copper pipes in order to repair and resolve problems. Other uses for this substance are in your garden or outside your home. It can remove dirt and debris from your grass and also from equipment in your garden. If you mix this with bleach, then you can make furniture outside look like new. It is also very good for getting rid of mildew that builds up on wooden decking and boards.
Safety
cleaning supplies
Despite how good it is at cleaning, trisodium phosphate is very strong and you should always wear protective gloves and eye protection when using so as to stay safe. If the cleaner comes in contact with the skin, it can cause major irritation and also burns if you do not use is correctly. Rubber gloves will help you avoid this when using it and also long sleeves and goggles to protect your eyes. Ensure that the substance does not touch bare skin. If it does happen, however, then you should wash that area thoroughly with soap and water and ensure you stop using it if your skin becomes red and is sore. You may experience irritation for longer periods as well as blisters. Additionally, it can be very painful to your skin.
If it gets near your eyes you should rinse them with clean water for around 15 minutes. You should also seek medical attention as soon as possible. If the cleaner is consumed by mistake, you should not vomit if you can help it. Instead, drink water or milk and then seek medical attention quickly. This particular cleaner is strong enough to cause damage to household surfaces and wooden objects. Painted surfaces may be damaged and the colors worn off. To avoid this, put down masking tape to protect surfaces.
