How to Choose Toilet Seat Hinges
1-2 hours
Beginner
- 70-150
It seems like it would be an easy job to purchase toilet seat hinges, but it is actually more involved than one would think. There are certain things to consider whenever you are purchasing new hinges. This article will provide the necessary details that will allow you to make the best choice to suit your own taste.
Determine the size of the Toilet Seat Hinges
Toilet seat hinges all seem the same, but that is not the case. There are standard sizes of toilet seat hinges, but there are multiple sizes from which to choose. If you have spent the money on an expensive toilet, then you will run the risk that the store will not carry a hinge that is made for that brand. That will either make it special order, or you will have to settle for another style.
To determine the size of the toilet seat hinges, measure the length of the current set on the toilet seat. The width of toilet seat hinges rarely plays a factor, unless you have a designer toilet seat. Pop the cap where the screws are hidden on the hinges and count the number of screws. It is also wise to measure the distance between the screws.
Choosing the Right Hinges
The cost of toilet seat hinges is relatively inexpensive. Determine which toilet seat hinges are available in the size you need, as well as the number of screws and distance between them. The list will certainly be much smaller. If cost is a factor, eliminate the styles out of your price range. The following toilet seat hinges are styles you may come across:
Plastic: Inexpensive, not very durable but easily replaced
Metal: A much better look, durable and a little pricey, but still affordable
Designer: More expensive and usually made for specific brands of toilets
Pneumatic: Expensive, but these toilet seat hinges stop the seat from crashing down, limited sizes
Rod and Hinge: Expensive but can usually be sized for any toilet, one long metal arm with hinges attached
Find toilet seat hinges that fit your toilet, then consider the aesthetics or functionality of the toilet seat hinges.
Installation of Your Toilet Seat Hinges
Remove the old toilet seat by popping open the screw cover and removing the screws. Place the new toilet seat hinges on the toilet base and screw the bottom hinge into place. Replace the seat and attach the top hinge to it.
