What Type of Garage Ceiling Is Best for You?
Most people use their garage for their cars and storage, while others might use it for an extra room. If that's the case, the ceiling in your garage should look its best and function for the environment. Especially if you will be spending time in there. There are a large number of ceiling options that do-it-yourselfers should consider for this use. Examples include popcorn, drywall, and Gypsum. It is best to figure out what type would work best for your circumstances. For example, if you live in the West, you might not need a heavy material, and if you live in the East, you might be better off with something sturdier because of the changing weather. Here are a few choices to consider when adding a garage ceiling to your existing garage.
Drywall
Drywall is one of the easiest and most readily available materials there is to work with. Drywall is basically plaster that has been layered onto a board so it resembles an actual wall. The material is sturdy and is used by builders and contractors everywhere because it is inexpensive and easy to work with. It can also be painted over and textured for customized looks.
Soundproofing
If you plan to use your garage for a loft or an extra room, think about soundproofing the ceiling. There are soundproofing materials often available from a big roll, at most home improvement stores. The effect of soundproofing is to attach the material to drywall boards. The boards will also hide the soundproofing material.
Gypsum
The latest material to be used in garage ceilings is called gypsum, which are ceiling panels that are constructed of sedimentary rock. Gypsum panels are often placed over a ceiling frame. They are manufactured to be smaller than drywall and are less expensive, however, gypsum is not suitable for rooms that hold moisture or are susceptible to water damage. And, it is not soundproof either.
Popcorn Ceilings
Popcorn ceilings were big in the 1970s but have pretty much fallen by the wayside due to their possible asbestos connection. It is called a popcorn ceiling because of its texture which resembles small kernels. It can be sprayed on or painted on the ceiling. If you want the popcorn look, you can texture the drywall you already have in place to look like popcorn by using a sponge on a coat of plaster.
Styrofoam Tiles
Styrofoam tiles are inexpensive and are an easy way to complete a garage ceiling. They come in large squares and are inserted into a frame already in place.
Cork
Cork has become a popular choice for ceilings because it is eco-friendly, looks nice, and is easy to install. Complete cork panels can be purchased at home improvement stores. They come either waxed or unwaxed, depending on whether or not you want the overall look of the ceiling to be shiny or dull.
Plastic Tiles
Plastic tiles come in all shades and sizes, as well as textures. They are cost-efficient and have come a long way in style since they first appeared on the market. Plastic tiles are manufactured to be fire retardant and often look more expensive than they are because of their various fashion-forward finishes such as tin, copper or other metals.
