When Is It Time for a Dome Skylight Replacement?
If you are trying to figure out whether you want a dome skylight replacement or not, you might find yourself on the fence. While replacing a skylight can be time consuming, there are many times when it is well worth the effort. To decide whether replacing your skylight is a good idea, you should consider the following.
Damage
Obviously, if a skylight is damaged, it is a good idea to replace it. A cracked skylight can lead to all kinds of problems, particularly water leaks, which can lead to further damage. Because of this, damaged skylights should be replaced immediately. As skylights are vulnerable to many forms of damage such as hail, this is probably the most common reason to choose to replace a skylight.
Additionally, some skylights have extra features that can cease to function over time. If your skylight can open and shut automatically, you might find that one day it no longer works. While you may be able to repair it, this may not end up being worth the effort when you compare the cost and effort of repairs to replacement.
Upgrading
Many skylights remain functional for a long time. However, newer models tend to have more and better features. If you have a bare-minimum skylight and you want the ability to open it and shut it from the ground, you may want to replace your old skylight with a newer model.
